Siemens PLC Interrupt
Mar 2012
Cork
Hello all!
I am trying to set up a high speed counter to count pulses from a sensor. I believe I need to set up an "interrupt". Can anyone explain what this is. I have searched through manuals and online but cannot find an explanation of how an interrupt routine works. Can anyone help?
I am using a S7 1200 with TIA portal V10.5.
Thanks in advance.
Hello all!
Thanks in advance.
In the CPU "Device configuration" > "General" > "High Speed Counters" you can set an Interrupt when the counter value is equal to a reference value. This is a hardware interrupt and will create an OB.
A "Hardware interrupt" OB will interrupt cyclic program execution in reaction to a signal from a hardware event. The events must be defined in the properties of the configured hardware
i want to know about interrupt subroutines in siemens s7 200 detaily
10,059
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
21
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
170
333
154
