siemens plcs conected to ethernet want to be able to go online via modem
dbolton
Oct 2004
preston lancashire
As part of my university project i am investigating a network of siemens plc's both s5's and s7's which are all conected together and to a scada via an ethernet network.
I need to know if it is possible to acess each plc's program so it could be edited or monitered from anywhere on the ethernet.
With the view to connecting a modem so each plc could be acessed from another site?
I know that normally the plc program can only by acessed normally via its progaming port is there another way or special card that can be added to each rack or is there another way of doing this?
Yes its possible, Basically one of our production facilities has this setup. We have a FI45 siemens PC running Windose NT
with Wincc collecting Data.We can access 10 S7300 + 2 S7400's (Connected via Ethernet) on this PC and remote monitor On/Off site via PC anywhere (a symantec product). The PC is also equiped with Step 7 & SimaticNet products.
Hope this what youn are looking for?
Regards
Steve
plc remote acess
thanks
so basically your using a normal p.c with s7 loaded on it as a programmer with pc anywhere software loaded on it.
(have seen that software used before when had trouble with a piece of german once machinery manufactures could go online via modem and my pogramer and you could watch the alterations on-line)
thanks again
Security searchers have found a security flaw with an hardcoded private key. Basically it affects every S7-1200 and S7-1500 CPU version before...
776
Hi, I have S7 Profinet PLCs with local IP addresses in my plant. Can I use the 1783-NATR to configure a 1:1 NAT to get to the plant network...
5,198
Hello to the Knowledgeable Masses, Our company is looking to dabble in the world of Siemens PLCs and HMIs. I am going to order a starter kit to...
30
8,913
Dear Friends; We have following Siemens PLCs at machines; CPU224 6ES7 214-1AD23-0XB0 CPU226 6ES7 216-2AD22-0XB0 CPU 319-3 PN/DP MODULE CENTRAL...
1,763
Hi, I am working on a project in Digi Module ConnectME9210 and sending data to Allen Bradley PLC (CompactLogix 5370 family). I am not sure which...
4,014
