abn015 Member Join Date Apr 2009 Location Philippines Posts 7 Jun 10, 2009 #1 Please see attachment for reference. In an S5 environment how can I change the value of the timer T10 with a set value of DW10. I need help here...
jvdcande Member Join Date Apr 2002 Location Menen Posts 2,178 Jun 10, 2009 #2 You simply have to change the value of DW10 to a new KT value. Unfortunately I cannot tell you where that DW10 is located, because you didn't show the rung where the appropriate datablock is called. Kind regards,
abn015 Member OP Join Date Apr 2009 Location Philippines Posts 7 Jun 10, 2009 #3 Hi, please see additional attachment look for PB60 segment 5. Thanks
Marshy Member M Join Date Apr 2007 Location Bath,UK Posts 236 Jun 10, 2009 #4 Having a quick look at your program. It seems, from OB1, that the open datablock is DB10. Therefore you need to change DB10.DW10
abn015 Member OP Join Date Apr 2009 Location Philippines Posts 7 Jun 10, 2009 #5 Thank You very much for the reply Marshy, I'll look into it...
