Siemens S7-1200 / Simatic Step 7
OK, my bad for believing what the print says....
Using TIA Portal V15.1 I come up with this info;
PLC_1
Short Description) CPU 1214C DC/DC/DC
Article Number) 6ES7 214-1AG40-0XB0
Hardware) 1
Firmware) V4.0.0
TIA Portal) V13.0
(this is the one that gives me the compatibility error)
PLC_2
Article Number) 6ES7 214-1AG31-0XB0
Hardware) 2
Firmware) V3.0.2
TIA Portal) V13.0 SP1
(this is the one that says it does not support PG/PC)
JohnR
PLC_1
Hardware) 1
Firmware) V4.0.0
TIA Portal) V13.0
PLC_2
Hardware) 2
Firmware) V3.0.2
JohnR
I think the compatibility error has been explained in the links provided by kalabdel.
I don't believe I've ever seen the "Does not support PG/PC" error before. Might be worth opening a case with Siemens tech support, if you haven't already. They are usually pretty decent in my experience, and generally don't require support contracts.
800-333-7421 or support.industry.siemens.com
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
502
Hi all, First time posting here. I have a Siemens Simatic S7-1200 controller that I intend to use for a small project at home. I also have a...
2,025
Hello - I have an old PLC file for a Siemens Simatic S7-1200 and I just need to see the ladder logic. If anyone has Siemens software, can you...
4,550
Hi, all. We have one AB drive (powerflex 525) and one SIEMENS plc (simatic S7-1200). Is it possible to make a connection between them via...
10,659
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
256
