Siemens S7-2xx ~ help required
mjamil
Apr 2002
PK
162
The HARDWARE:
S7-226, Microwin (will possibly upgrade to version 4, from current 3.2), HMI (Maple systems) with a Parallel port, attached to a printer.
SCENARIO:
I need to save data (to the PLC's memory) and than print a report something to this ...
REPORT PRINT DATE JUNE 1, 2005
TIME: PRODUCTION REJECT BLAH#1
08:00am ~ 09:00am 200 10 xyz
09:00am ~ 10:00am 230 5 abc
10:00am ~ 11:00am 178 32 wow
Total Production 608
Total Rejection 47
Time / Date stamp can be in any format, as long as it is in English!
What I am interested in how to load (save) all this data, on a S7-2xx, I am aware of its limitation, but have never gone this far in loggin data to memory, I have been checking stuff at siemens, they do sell a 64K (or 256K) memory module for data logging, recipe, etc (and amazingly its cheaper than the older 32K mem. modules!)
any help would be appreciated.
Hi, I've wired the Thermocouple module, and done some testing. Everything seems fine from the Wiring and reading the value point of view...
2,334
I am wondering why Siemens CPU2xx do not have normal timers for use and they only have Delay ON or OFF timers.
3,005
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
123
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
157
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
172
