Siemens S7 and Protool Integration (symbols lost)
kemppioy
Oct 2005
Dallas
72
Hello,
I have an S7 project that has protools integrated. I somehow lost the symbols in protools so I cannot use them when i add an object and want to select the tagname from the list of symbols. How can I get the symbols back? I tried to compile both the panel application and the plc but that did not help!
PK
Terve Kemppioy
Have you already check your connection from OP to PLC? (Protool, Contreoller, Parameters, choose your communication peer MPI/DP) Do this again, save and compile -> it should work.
I have had this same problem couple of times.
Pete
As Pete say, resetting your parameters is the clue to getting your symbols back, but once you've done this you also need to relink them. You do this from the Edit menu, I'm not quite sure what the command is called in English, since I use a German version, but it should be easy to recognise. I expect it will be something like "Relink Symbols" or "Recover Symbols".
If you can't find it, post again and Jesper will be able to tell you what it's called in English (and where to find it I've guessed wrong for the Menu).
Hi RMA
The word what you are looking for is "Restore Symbols". Is it Under Edit menu.
In my experience: When you attach the panel program from "old project" to new project you must do this... Like check your peer to peer connection, save project, restore symbols, and last and finally Save and Compile..
Also, check your PLC hardware and see that you have selected "Networked" = YES, and that they are on the same network,in the CPU setup. By default it is NO. Without networking the PLC and ProTool panel, you will not get the link for the symbols.
[FIN]Pete said:
Terve Kemppioy
Pete
Yes that was it! Hey that was simple! More tough question to come!
Thanks for your help!
PK
s7 symbols lost
[FIN]Pete said:
Terve Kemppioy
Pete
Where is this conection set from?
I open the simatic manager, open my project, and double click the operator panel.
Protool opens up, but I do not have the Controller option.
I couldd not find it from simatic either.
The simatic manager still shows the MPI connection.
Thanks for the help.
Mark
Hello, I am trying to break in into project from 2012 because it may require some modifications. Currently I am in stage of trying to understand...
2,430
I am trying to convert a Protool backup to WinCC 2008 SP2. I can start the migration wizard and the PDB file passes the consistency checks. But...
2,159
Hello I have a project for which I need to convert Protool to WinCC for an upgrade. I have WinnCC Flex SP2 but its the Standard version and I...
3,652
Does anyone have the old ProTool software from Siemens? I was wondering if someone could open a project for me or sell me the software. From...
7,967
2,865
