SIEMENS S7: Export and Imort Data blocks from STEP7 to EXCEL
Jul 2003
Mumbai
27
Hello Guys,
Is there any way to export / import the data blocks from EXCEL files?
We tried in S7 and find very difficult to export. In EXCEL the values are not differentiating between different formats.
For example excel reads as INT and REAL values in one format only.
Please suggest if any solution for this...
Thank You
Apparao
Use the "generate source" function in the manager. The for example copy/paste to Excel. Build your DB in Excel, then paste it to the source file. Then "compile". Very good for creating large datablocks build of UDTs where each object has its specific name.
All the data comes out as HEX, I have done this often and just used the Excel tools to make my own conversions in look-up tables.
I am using Siemens Step 7 v5.6 I am trying to Export all Tags along with the tag comments for a excel sheet. Does anyone have any idea how to...
8,889
Hi all! I would like to be able to export some data from a Siemens Comfort panel. I want to end up with a nice PDF document, but I am...
3,261
I have a S7 project originally written in German that I am trying to troubleshoot. Can the symbol table be exported into Excel then translated and...
3,933
Hello, I am trying to find an easy way to create data blocks in Step 7 with ~100K tags other than manually defining each tag in the LAD/STL/FDB...
14,227
Hello All, Is there a way in Step 7 5.5 SIMATIC Manager to export a data block so that it can be imported into another project with all...
3,740
