Siemens S7400 timer value preset help
kegman
Oct 2003
London
25
Hello,
i need some help with attaching a preset timer value to a timer. This is the scenario.
i have a conveyor system that transports 18 different products ( one product run at a time )
Each product, or format has a saved menu consisting of timer values, counters etc. These values are stored in data blocks, 101-118. One for each format.
When the operator selects a format on the touch screen HMI, the saved menu i.e Db101 ( format 1 ) is transfeered into a working menu DB100. All of the saved presets loaded into DB100 are then used within the S7 software.
i wish to add an a new timer value which will be used for all formats. However, each format requires a slightly different timer value.
I want to use one timer ( T50 ) and load the timer value stored in DB100. So, instead of inputing a S5time value i want to input DB100.DBx8.0 I will then assign DB100.DBX8.0 a value and list it in the data block as S5TIME.
Every time i try to input the Db into the TV on the timer it turns red so obviously the syntax is incorrect. Can anyone help?
Thanks.
Jason
Thanks Simon,
I had already tried the DW8 but because i hadn't assigned the correct elementary type within the format and working DB's it would not let me insert.
Cheers,
Jason
Hi all, i'm working on a machine equiped with a s7400 and another plc called ROBOX. There is an analog value(0-10v) from that robox going to a...
2,307
Dear all, I'm basically into DCS. As a part of my job I need to maintain few AB controllogix PLCs and Siemens S7400 PLCs. As if now, I'm looking...
4,988
Hi all, Has anyone engineered a RSView SCADA sitting on top of a Siemens S7400? i have not come across this combination before, only RSView on...
5,367
I just had a vendor change his mind on the type of Siemens PLC he wanted to use from an S7-400 to an S7-300. After printing all of the S7-400...
6,041
I would like to communicate with Simens S7300, S7400 using Visual Basic. I want to know any other possiblity except OPC to communicate the same.
4,388
