How does one export an entire project in TIA v11? Tags, program blocks, hardware config, HMI screens, network info, code, the works?
Is there some trick to this? I had heard that one must copy and paste tags and program blocks etc, rather than a simple 'export' or library as I'm used to?
The end goal is to have the complete project on my computer on the other side of the planet, via a zipped file. Then I can implement the changes I need to in the system after the intial TIA software learning curve. A working project will be greatly beneficial, then at least I can play in PLC sim while I am coming up to speed.
