simadyn-d hardware fault
Apr 2006
Rourkela
18
Hello Experts,
We are using a Simadyn-D system for Basic Automation in Hot Rolling Mills in our Steel Plant. The system communicates with external system over Sinec-H1, DUST4 (For HMIs)etc. The recieved data is assembled and sent to other SImadyn-D based drives through Parallel Frame link (CS-11).
The system is giving Hardware fault in one of the processors.
There are 3 processors in the system. The hex dump gives error cause as time-oyut while accessing L-BUS.
Can anybody suggest a way to analyse the faults or some group who can help in analysing the faults?
Kindly help.
M.B.S.Namboothiripad.
The h/w fault shows the reason as Time-out on L-Bus. The communication with Sinec_H1 is on C-Bus. More over if there is communication fault, it gives C on processor. We have changed the PM4 card, which is used for $ communication(PN). There is no much improvement.
Did you face any similar problem ? Is yoyur solution based on your experience on similar problem?
Pls elaborate.
Hi, Anyone does have Simadyn D Struc v4.2.4 to assist burning some MS5 memory modules? I have all the compiled files. regards
71
Hey Guys, I know I'm reaching out there, but right now I'm working on a project with some older Simadyn-D controllers. I'm viewing the existing...
4,173
Hi Dear, we are useing PM12,PM13 processor for drives control.now we are using op1 panel for parameter and monitoring. any one have same...
1,129
Hi, I am looking for a EPROM burner tool for Siemens Simadyn D system. This is an obselete system not supported by siemens. Thanks in advance for...
2,239
Hi,...... I'm looking for free software for SIEMENS SIMADYN D (STRUCT V), where I can found it.? Thank's for your help hadi
4,715
