slc 5/03 processor's fault led glows constantly
suvro2012
May 2012
Dhaka
23
Hi
My Slc 5/03 processor's (cat no. 1747-L531) fault Lamp Glows red constantly. and communication LED(DH 485 and RS 232) is not glowing. so i can not communicate with my processor. Any one have any idea what might be the problem and what would the solution?
Possibly the processor memory has been corrupted.
Try to go online via the DF1 port, and try to use autoconfigure.
Is there an EPROM in the CPU ?
If so, are the bits set to load the EPROM on memory error ?
If all the above fails you might try clearing the memory. Hopefully you have a back-up of your program. See PFG's below
I have found that the EPROM is Missing of my cpu.Without the EPROM can the CPU Communicate?
I have a SLC 5/05 processor with a Major Fault 1F39h. The processor is running fine with the fault, but I would like to know what is causing it? I...
3,837
Hello all, I noticed our "Airmaster" PLC which is a SLC 5/04 processor was in Fault when I connected to it via DH+. I cleared the fault and put...
1,908
Good day all. I have a SLC 5/03 with a fault that I can't put my finger on. I've attached two projects. The one named "...In Processor" is what is...
4,895
Hy guys, I think i have a little problem with my old HSCE2 module for SLC 5/04 processor. Well ... i can't acces the M0 file from module !! Does...
3,351
I would like to post this thread as a correction to an old one that i posted last week. We have a AB SLC 5/05 with 1747-L551 showing fault LED...
16,257
