Slc 505 on ethernet question
stu
Aug 2005
England
783
Hi guys
I hope your all safe and well , I have a question regarding a slc 505 on ethernet is it possible to add a ethernet remote I/O module like a Phoenix connect 2701496 to a slc plc , and if so do I have to use Gsv instruction for the i/o in the plc ?? Is this the best way to do this ??
I don't believe they support remote I/O over Ethernet in any way.
In my opinion, you're better off using MSG instructions to another processor with I/O if you have to control something with a SLC over Ethernet.
Rupej is correct.
Here is the official Rockwell answer:
SLC 5/05 does not have the ability to do any types of Remote I/O over Ethernet.
Alternative solution will be having a Logix processor talk to the Ethernet Remote I/O, and then send the data to the SLC 5/05 over Ethernet.
Yea the only think a SLC can control over Ethernet is AB drives that support it. Even then it acts like a PLC-5.
The later SLCs support advanced messaging but not the required CIP connections.
The SLC-5/05 controllers are not intended, designed, advertised, or supported to control I/O devices on Ethernet.
While you can sometimes send unscheduled Ethernet messages to certain devices (including Rockwell AC drives) to implement a functionally equivalent feature, unless you are very familiar with MSG programming and your SLC-5/05 control system's current loading and capacity, I very strongly recommend against attempting to do so.
My counterpart and I spent the whole day today trying to setup a SLC500 to send a start command and speed reference to 20 HP powerflex 753 today...
3,750
Can any one point me in the right direction for setting up communications with a slc505 processor and a programming terminating via ethernet?
2,157
I have a SLC 5/05 with really slow Ethernet comms. It is on a network with three Proface screens but comms is just as slow when I connect directly...
3,931
Good Evening, I just received a new laptop and need some assistance. My old setup worked well. So same cables, Ethernet Switch etc. Only thing...
2,562
Could someone please help me with a code snippet of SLC505 ethernet communication with powerflex 70 and 40 drives. Have done this with rsview...
2,649
