Some questions about Siemens Coros OP25
zanor
Sep 2005
Oppland
I just got my hands on a Siemens Coros OP25 but I have no idea on how to program it...
After reading on this site I found out that I must use Protools(?)
Does anyone have a manual for ths device? Tried searching the Siemens website but I could not find the manual for OP25 but just about every other device :(
How do I connect this to a Siemens S7 200 (CPU 222) PLC? (anyone have a wiring diagram?)
How do I connect this to a PC for programming? (Wiring diagram anyone?)
Thanks!
The OP25 do indeed need to be programmed with the Protool software package. The OP25 old now, but probably fully functional. I wouldnt use it for a new project, but it is OK for learning on.
It can connect to the S7-200 via PPI protocol.
You probably do NOT need to consider Profibus.
Thanks for the answers!
But how do I connect the OP25 to my computer for programming?
This PPI cable between the PLC and OP25 is this just as simple as connecting pin 3 and pin 8 on both devices? (+shield)?
I need some clarification. Do they have something called Fetch/Write that is different from Get/Put? How do they differ? Are they serial or...
2,152
Question for the Siemens gurus here. We have one stand-alone piece of equipment that is running an S7-1200 processor. The manufacturer has...
2,423
Hi Everyone, I am new to siemens servo drives, needs some helps and wondering if you can help me. The machine has Siemens S120 Servo Drvie and...
1,652
Hi - I am unfamiliar with Siemens PLCs but have been given ownership of an S7-300 CPU318-2 with IO and a network interface card at site. The PLC...
18
4,307
I have some very basic, some might say stupid, questions. I'm an AB programmer being forced to convert my program Siemens. I'm slowly coming up...
3,347
