STL code problem
userxyz
May 2002
any
2,768
Code:
 FUNCTION "Auto_Weergave2" : VOID
TITLE =Grafische weergave van de cyclusverwerking
VERSION : 0.1
VAR_OUTPUT
  i1 : INT ;
  i2 : INT ;
  u1 : INT ;
  u2 : INT ;
END_VAR
BEGIN
NETWORK
TITLE =
	  A	 I	  0.4;
	  SET   ;
	  JC	toil;
	  L	 0;
	  T	 #i1;
	  L	 0;
	  T	 #i2;
	  L	 0;
	  T	 #u1;
	  L	 0;
	  T	 #u2;
	  BE	;
NETWORK
TITLE =
	  CLR   ;
toil: A	 M	  1.0; // 1e aanvoer
	  JCN   _1;
	  L	 1;
	  T	 #i1;
_1:   NOP   0;
	  A	 M	  1.1; // doorgezaagt 1
	  JCN   _2;
	  L	 1;
	  T	 #i2;
_2:   NOP   0;
	  A	 M	  1.2; // 1e afvoer
	  JCN   _3;
	  L	 0;
	  T	 #i2;
	  L	 1;
	  T	 #u1;
_3:   NOP   0;
	  A	 M	  1.3; // doorgezaagt 2
	  JCN   _4;
	  L	 2;
	  T	 #i2;
_4:   NOP   0;
	  A	 M	  1.4; // 2e afvoer
	  JCN   _5;
	  L	 0;
	  T	 #i2;
	  L	 2;
	  T	 #u1;
_5:   NOP   0;
	  A	 M	  1.5; // doorgezaagt 3
	  JCN   _6;
	  L	 3;
	  T	 #i2;
_6:   NOP   0;
	  A	 M	  1.6; // 3e afvoer
	  JCN   _7;
	  L	 0;
	  T	 #i2;
	  L	 3;
	  T	 #u1;
_7:   NOP   0;
	  A	 M	  1.7; // doorgezaagt 4
	  JCN   _8;
	  L	 1;
	  T	 #i2;
_8:   NOP   0;
	  A	 M	  2.0; // 4e afvoer
	  JCN   _9;
	  L	 0;
	  T	 #i2;
	  L	 1;
	  T	 #u1;
_9:   NOP   0;
	  A	 M	  2.1; // doorgezaagt 5
	  JCN   _10;
	  L	 2;
	  T	 #i2;
_10:  NOP   0;
	  A	 M	  2.2; // 5e afvoer
	  JCN   _11;
	  L	 0;
	  T	 #i2;
	  L	 2;
	  T	 #u1;
_11:  NOP   0;
	  A	 M	  2.3; // doorgezaagt 6
	  JCN   _12;
	  L	 3;
	  T	 #i2;
_12:  NOP   0;
	  A	 M	  2.4; // 6e afvoer
	  JCN   _13;
	  L	 0;
	  T	 #i2;
	  L	 3;
	  T	 #u1;
_13:  NOP   0;
NETWORK
TITLE =
	  L	 MB   141;
	  L	 4;
	  ==I   ;
	  JCN   off;
	  L	 1;
	  T	 #u2;
	  L	 0;
	  T	 #u1;
off:  A	 I	 20.6;
	  JCN   noff;
	  L	 0;
	  T	 #u2;
noff: NOP   0;
END_FUNCTION
Strange thing is, when I connect A Merkerword MW100 for example, the value u2 will be zero, when I connect the DB35.DBW6, then I get a weird value, anyone an idea how this is possible ?
hmm
Can it be because I connected to an OUT, should I use IN/OUT parameter...
ill try this..
Combo said:
Code:
VERSION : 0.1
VAR_OUTPUT
i1 : INT ;
i2 : INT ;
u1 : INT ;
u2 : INT ;
END_VAR
BEGIN
NETWORK
TITLE =
	 A	 I	 0.4;
	 SET ;
	 JC	toil;
	 L	 0;
	 T	 #i1;
	 L	 0;
	 T	 #i2;
	 L	 0;
	 T	 #u1;
	 L	 0;
	 T	 #u2;
	 BE	;
NETWORK
TITLE =
	 CLR ;
	 JCN _1;
	 L	 1;
	 T	 #i1;
_1: NOP 0;
	 JCN _2;
	 L	 1;
	 T	 #i2;
_2: NOP 0;
	 JCN _3;
	 L	 0;
	 T	 #i2;
	 L	 1;
	 T	 #u1;
_3: NOP 0;
	 JCN _4;
	 L	 2;
	 T	 #i2;
_4: NOP 0;
	 JCN _5;
	 L	 0;
	 T	 #i2;
	 L	 2;
	 T	 #u1;
_5: NOP 0;
	 JCN _6;
	 L	 3;
	 T	 #i2;
_6: NOP 0;
	 JCN _7;
	 L	 0;
	 T	 #i2;
	 L	 3;
	 T	 #u1;
_7: NOP 0;
	 JCN _8;
	 L	 1;
	 T	 #i2;
_8: NOP 0;
	 JCN _9;
	 L	 0;
	 T	 #i2;
	 L	 1;
	 T	 #u1;
_9: NOP 0;
	 JCN _10;
	 L	 2;
	 T	 #i2;
_10: NOP 0;
	 JCN _11;
	 L	 0;
	 T	 #i2;
	 L	 2;
	 T	 #u1;
_11: NOP 0;
	 JCN _12;
	 L	 3;
	 T	 #i2;
_12: NOP 0;
	 JCN _13;
	 L	 0;
	 T	 #i2;
	 L	 3;
	 T	 #u1;
_13: NOP 0;
NETWORK
TITLE =
	 L	 MB 141;
	 L	 4;
	 ==I ;
	 JCN off;
	 L	 1;
	 T	 #u2;
	 L	 0;
	 T	 #u1;
off: A	 I	 20.6;
	 JCN noff;
	 L	 0;
	 T	 #u2;
noff: NOP 0;
END_FUNCTION
Hi, I've got this code and want it in ladder. My biggest problem is what the first line means L B#(52, 1) CALL FC 58; T MW 60 Thanks...
1,650
Hi, problem I have is... I have a step program, and in step 60 I get a break of a few seconds, while everything seems to be good... I did not...
4,723
Hi I have problem to understand this code? can anyone explain this code for me? L B#16#3 L #OBJ_NR SLW LAR1...
2,471
Hey everyone, In the middle of deciphering STL code in S7 plc and I'm confused. I interpret the following code to be load the register "#Step"...
2,077
Hi, Anyone know why this network is not longer shown in LAD format but only in STL ? O "RB 20878".EinfV O "RB 20878".EinfR...
2,575
