stop RSLinx from starting with RSView
jimtech67
Jun 2002
New Jersey
509
Hello again
I am using RSView with an OPC server that is not Allen Bradley and it works fine. I do not need RSLinx running. My question is how do I stop RSLinx from starting when I open a project??? I looked around the software but could not find what I need. I kow how to stop RSView from start ing as service when I start my computer.
Jim
Go JETS
Don't know if this helps but:
Have you tried running the RSLinx Launch Control Panel?
Stop RSLinx Running using that and then uncheck the RSLinx Always run as a service button.
Running XP or 2000.....
Go to control panel
Go to Administative tools
Go to services
Look for Rslinx
Double click
Stop the service
In the start up type. select disabled or manual
Ta da
If you are running 98, Upgrade :D
Also, if you are not calling any RS drivers that are configured in linx, it should not start it. I could be wrong tho....
IIIIIIIII got a feeling........ Pittsburgh going to the super bowl! ya!
Jets... HA! :p
:cool:
I know how to stop the service at 2000 startup and I only have the OPC server configured as a node in my application and RS linx still starts up when I start up RSView works. Any sugestions?
Jim
Go JETS
Little know feature (apparently)
Jim:
Have you installed the RSView Resources Toolkit? If not, do so.
In it, you will find a utility, Registry Configuration. Running it, there are many settings that can be configured.
One is:
Start RSLibx Automatically at Startup - - - - TRUE.
Change it to false, and RSLinx will not start up the next time you start RSView.
What every one else was talking about will prevent RSLinx from starting when your PC starts, which is a different issue.
It is there and works. I did not install the RSView Resources Toolkit because I am building a simple application and did not think I would need the extra features.
Jim
GO JETS
I need to uninstall softlogix, but first need to get linx stopped. I can get it stopped but it keeps restarting. I am not running any other...
7,639
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
312
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
320
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
418
I'm looking to get some spare keys for this PLC. Does anyone know a source or have a part number? My searches are turning up nothing at the moment.
104
