Studio Logix 5K V30 - Trend
alive15
Oct 2015
Montgomery, AL
724
Good morning,
1- I am finding good use out of the Trend feature in Studio Logix 5K. Is there a way to export the graph into a pdf automatically after every cycle I run (I would automate the start and stop of the trend)? I know how to export into PDF manually, but would like to automate this through the software.
2- The data I need to collect would be plug depth vs. pressure exerted over a 2 second period. I am seeing pressure from a depth between 3.5 and 4.5 inches.
3- If I cannot automate the graph into pdf, would my PLC (1769-l27erm-qbfc1b) work fast enough to capture this data into an array of 100? For example, at 3.5 inches, psi = 50; at 3.51, psi = 52; at 3.53 psi = 60, and so on until 4.5? Then I would save the data of 100 points into a notepad through my Automation Direct HMI, and redo for each cycle.
Good morning,
Yes, it will be more than fast enough.
Use AdvancedHMI to do the collection and then use VB.Net to output the data in the format that you want. Piece of cake.
I've used AdvancedHMI to collect data and then output it to Excel (creating the Excel SS internally since the company was too cheap to buy a copy of Excel), as well as to MySQL, and for data collection just like what you want to do.
Hello, hope everyone is doing well. I'm programming on RS Logix 5000 / Studio 5000. Is there a way to do math inside an instruction using tag...
2,877
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
383
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
146
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
302
