Text Messages
dsprules
Nov 2005
essex
CAN YOU USE AN SLC 504 TO SEND TEXT MESSAGES e.g PRODUCTION SCORES.IF SO WHAT EQUIPMENT WILL I NEED TO DO THIS
THANKS
DARREN
Fairly straight forward Daz. Just get yourself a GSM modem (Westermo, Siemens etc). Hang it off CH0 of the 5/04. Then write yourself a bit of code (using the Ascii commands, AWT etc) and Bob's your proverbial. :cool:
If you search back through the forum there are loads of examples (i've posted a couple myself - even some sample code) - for you to try....
You can send a text message with as little as 2-3 lines of code....
Not sure what level of detail you needed?o_O
Hope this helps!
Regards
Rob
Thanks Rob ,
I will look in to this .What i need to do is connect 8 plcs together using DH+ then every hour send the production scores automatically to the mobile phones .
Again, quite straight forward....Are you going to gather the production totals on one machine, then use that one (with the modem connected to it) to send the text messages?
You can pick up a GSM modem for less than £100, so if you've already got the 5/04's networked, then it should be relatively inexpensive to implement what you want to do...
Hope this helps....(y)
Rob.
Folks, I just joined the forum ! Please suggest/advice about possible options for receiving event notifications over text messages on a CDMA...
3,110
Hello, I'm trying to use the CJ2W-CPU32, westermo MRD 315 to send messages in case of problems to the operators. Where should I configure the...
2,633
Sending email messages from the PLC sounds like an easy task. However, very few applications do this on the production floor. This is probable due...
6,649
Gents, Can anyone give me an example, a quick guide to do the following thing: I've a Panelview 1400 and a Panelview 600 both on the same...
1,327
Question for EZText 220P experts: Sorry if this is obvious somewhere in the program but I have been pulling my hair trying to use Line 2 PLC...
5,699
