TIA Portal Creating Faceplate
qwemx
Jul 2017
Earth
195
Hi Experts,
I have created a face plate and to make the objects on it visible and invisible
for this i created a tag Bool called Show hide Face plate
All the objects on the Face plate have been configured in visibility to hide if this Tag bit is 0 and show up when this tag bit is 1 . However in sample example downloaded from the Siemens Website I saw there is a connection to be established by drag and drop between the Objects and this Show Hide tag
So i went to the object properties and expanded the list, Visibility is not there then how do I establish a connection ??
screenshots
https://imgur.com/gallery/63mXsB0
Hi qwemex
Hi you reported your own post and asked it to be deleted, because the problem had been solved.
But posts can only be deleted if they are spam.
Also, even if you solved the problem by yourself, it is not the proper way that the post be deleted.
Instead, post what was the problem and how you solved it.
Hi qwemex
It was solved by Creating a new Tag in the HMI <internal tag >
All the Tags inside a Faceplate are not accessible from outside
but this showhidefaceplate tag can be connected to this HMI tag and also the Button on the Home screen can also be connected to this HMI tag
so basically it acts like a middle man
Faceplate ShowHide Tag(accessible from inside of faceplate ) ---connected to ---HMI tag(internal tag) -------connected to Event property of button on main screen
Hello, As a person who is not that experienced in plcs i am new to a lot of things in this environment. Today my problem includes the alarms...
1,373
Hello everyone, As you can see in the screenshot below i have some values that are retentive. Now i want to create a specific value for specific...
1,512
Hello I'm looking for a way to do the following but i don't know if it's possible.. I use Wincc TIA V15 comfort panel i use the recipes as...
3,578
I am using CPU 315-2 PN/DP which doesnt allow to assign the variables to the created UDT , meaning the created UDT"PLC Data type" doesnt show in...
2,833
Hi, If I were to create an INT for my FB / DB, will this use up a whole DINT every time I use one or will is just use an INT's worth of memory...
1,875
