Very Urgent Project Requirement in Step-7
Step7_aby
Feb 2008
Abu Dhabi
22
hi guys, please help me out from the below mentioned problem as soon as possible as its very urgent for me and the FAT in coming days.
I am using Step-7, V 5.4 sp-2, CPU-412-2
The concept that i have to implement is as follows i am having one GPS device that will give pulse to PLC at certain interval of time and with this pulse, "Second" and "milisecond" of the PLC has to be reset to "0" and the minute has to be incremented by 1;
Eg: let the module time be 10:33:45:015 ( pulse comes at this time )
at the pulse
the module time shall become
10:34:00:000
Please guide me at the earliest along with code if possible in STL.
Thanks in Advance.
at the pulse
10:34:00:000
Thanks in Advance.
As been said by many, We are not answering homework assignment here in this forum. You need to show us what you have been done in this type of project, then that the time we will give answer to you and help you. A lot of guys will help you here but you need to do your job first!
Starting a new thread in a larger font isn't going to get your problem solved any quicker - it's just spamming the board.
You have made very little or zero effort yourself in both defining your problem or coding a solution to it.
We are not here just to supply your S7 code on demand.
To handle the case where incrementing the minute will cause a roll over, Lets say system time = cd:59:ab:xyz when pulse arrives. if xyz < 998...
2,203
Hi Guys please someone help me and take it as ugent requirement for my project, I am using Step-7, CPU 412-2 here and the logic that i have to...
4,169
I just ordered a handy programer TOSHIBA HP-100 but i have not the cable to make connection to the cpu PU11A. Please someone help me with the...
2,521
1,791
1,783
