Viewing program in S5-90U
burnerman
Nov 2005
Huddersfield
212
We are upgrading some old equipment for our client, part of which is a machine controlled by a S5-90U plc and a bunch of relays & timers. We have to modify the way the machine works and add some interlocks from other machines in the process.
As is usual with these sort of projects: no drawings, no programming equipment, no plc program printout, etc. etc. Therefore we need to reverse engineer the old system.
Can anyone advise what's the cheapest/easiest way to view the current program (software/lead or HHT)? - we don't need to make any modifications to the original as we'll be throwing the S5 & relays out and replacing with a new PLC.
burnerman said:
Thanks GIT for the link, hopefully 10 minute demo will be long enough to get info I need....
You can just restart the software and get another 10mins
burnerman said:
Any clues for the cable?
this is the cable, you may find someone in your area that will lend you one, I buy them from tt, you can get them from Siemens also
http://www.ttintl.com/english/connect.html
I am new to PLCs altogether. I work almost exclusively within Emerson's DeltaV. I have a standalone PLC with a RSLogix 5000 version 10 program...
1,826
I downloaded the Emulate 500 and RSLinx trying to view a .rss file. It opened but I didn't see the ladders. Can anyone help me with this? Thanks
1,260
This is something that's been annoying me on and off for months if not years, but I've finally got sufficiently pi$$ed off to want to get to the...
4,403
I am working on a project to upgrade an exisiting system comprising of a Symax model 300 PLC. I have a backup of the existing PLC program. I need...
2,991
Does anybody know an easy way to open up an S7-GRAPH Block directly in the STL-Editor. That is without going to the trouble of either...
6,069
