Weird RSLogix500 Problem, anyone else seen?
Dec 2010
Burlington, NC
402
We recently upgraded a machine from a PLC5 to a Contrologix, used the conversion utility to convert the logic. Had to change over messaging to other PLCs from DH+ to Ethernet, so we wrote new message instructions to cover them. The system ran fine until today when I was changing over tags to get rid of the old PLC5 format (B3:nn/n, etc..). When I tried to finalize the tag changes I made the message rungs were in error, and the instructions were listed as unknown ( a XIO and a MSG). Has anyone else seen this glitch before?
Mark Snodgrass
I do recall having somehow corrupted an instruction for lack of a better term...
I had to type in a new identical rung and then it was accepted and I could drill into the dialog boxes.
Greetings Mark ...
I've seen it do the trick shown below on a few occasions ... it seems to happen most often whenever the moon is full ...
I've seen this happen as well, it seems like it occurs when there are multiple people online with the processor making edits. Usually the other person making the edits still has a good copy of the program. Are you able to do an upload from the processor? Does that resolve the problem? If not, AFAIK doing a fresh download is the only way to fix it.
Ron, Yes the moon was full when it happened!:ROFLMAO: And you picture was very like what we had, except the xio and the msg were in separate UNK instructions.
gitargr8, We did have multiple computers online doing various edits. I thought RA had improved from the PLC5 where you would get kicked off when someone else made an edit, but I guess it seems like they created another possible issue to look out for.
I had deleted the rungs before I realized what they were for, figuring they were some old code not used by CLX (BTR,BTW). When we started having problems due to the lack of messaging, I wrote new rungs and the problem went away (Thankfully CLX tags keep all the setup info and that part was easy to redo). After checking with the guy who wrote the messages originally I found his copy to be correct. We will just have to keep an eye out for this in the future when multiple people are online at the same time making changes for a startup.
thanks
Mark Snodgrass
I have created a project in TIA Portal v16 Upd6 with S7-1200 (6ES7214-1AG40-0XB0) and WinCC Unified (PC station). The communication between the...
154
I currently have a weird issue involving Ethernet IP communication between a ABB CI873 (EthernetIP Module) and a 1756-L83ES. The Layout is as...
764
Good morning. I'm doing a rehab and I need to recycle some part of the old code that won't change and that I need. This is a calculation that...
22
1,374
I'm trying to figure out a weird behavior I'm seeing in my CCW program. It's for controlling a gas polarizer (for medical imaging). I'm using an...
465
I'm trying to figure out some weird behavior I'm seeing in one of my programs. This should be fairly straightforward - except that it's not...
954
