I believe you only see "unwind" when you setup the axis to be "Rotary" Positioning. This means that after moving for x units, the position is back to the starting point. For example, a servo is turning a wheel on a car. After traveling 360 degrees, it is back to where it started. Depending on how you are setting things up, it may be 360 degrees or the tire circumference inches or whatever units you're working with.
If you set your positioning to "linear" I don't think you will see anything related to "Unwind"
