What is the difference between a 1756-ENBT and a 1756-EN2T ?
Rob S.
Sep 2008
Maryland
739
Good Evening ,
We are getting ready to replace some machinery and the manufacture is planning on using a 1756-EN2T . What is the difference between the 1756-EN2T and the 1756-ENBT ?
Thanks so much for your help ,
The most important difference is probably that the older 1756-ENBT does not support Motion or Safety over EtherNet/IP.
The 1756-EN2T is newer, faster, and higher-capacity.
It's more or less backward compatible with the 1756-ENBT, if you disable electronic keying and aren't doing something fancy like Redundancy.
The 1756-EN2T and 1756-EN3T also have Fiber variants (-EN2F), and Device-Level Ring variants (-EN2TR). The -EN2x and -EN3x have the same I/O capacity, but the "3" supports more motion axes.
Good Evening , Could you folks tell me what the difference is between a 1756-L62 A and a 1756-L62 B ? I found a 1756-L62 A , but all the...
2,505
Is there any difference between these batteries other than the connector style? We have a ControlLogix L61 processor with a dead 1756-BA2 battery...
14,383
Hi, What's the difference between Rockwell Controllogix 1756-ENET and 1756-ENBT card? Are they compatiable? Thanks,
8,213
Guys, I'm configuring a redundancy system (network, CPU, power supply), i used to use 1756-CNBR at the remote chassis. I'm not sure what is the...
11,414
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,429
