iant Lifetime Supporting Member + Moderator Join Date May 2002 Location Melbourne Posts 3,691 Mar 20, 2012 #1 Hi All Which plc make uses file extensions .upr and .dpr I thought unitronics - but not the case
MarkNightingale Lifetime Supporting Member + Moderator M Join Date Sep 2010 Location In The VAT Shed Posts 740 Mar 21, 2012 #2 Ian, We have got a SCADA type application that was developed using Delphi, and that has the file extension .dpr. I'm not sure if yours is the same. http://delphi.about.com/od/beginners/a/delphi_dpr.htm Mark
iant Lifetime Supporting Member + Moderator OP Join Date May 2002 Location Melbourne Posts 3,691 Mar 21, 2012 #3 thanks I will have a look but it is supposed to be a plc and kepad style HMI
iant Lifetime Supporting Member + Moderator OP Join Date May 2002 Location Melbourne Posts 3,691 Mar 21, 2012 #4 Delphi is a programming language - I use to have a copy of Borland delphi - about 12 years ago - but might still not be the info I need
MarkNightingale Lifetime Supporting Member + Moderator M Join Date Sep 2010 Location In The VAT Shed Posts 740 Mar 21, 2012 #5 They used Borland Delhi when they installed this SCADA, but unfortunately I don't have the software myself, so I can't see if that will open it. Mark
iant Lifetime Supporting Member + Moderator OP Join Date May 2002 Location Melbourne Posts 3,691 Mar 21, 2012 #6 I will just have to go and search the storage - I still have Delphi that is the SCADA - now the UPR
STL??? Member S Join Date Sep 2005 Location UK Posts 879 Mar 26, 2012 #7 UniOP use the extension's you mention with there Designer software link
iant Lifetime Supporting Member + Moderator OP Join Date May 2002 Location Melbourne Posts 3,691 Mar 26, 2012 #8 looks good I will download and try thanks
