WinCC flex .. multiple HMI, same project
cjd1965
Apr 2007
UK
1,659
Hi
I have a request to use upto 6 wincc flex panels, 1 will be the MAIN unit, others wil be remote, with reduced functionality (2 mimic displays and alarms)
I want to create a single project the change the start up page to point to the MAIN or MINOR pages.
My question is about alarms. If I use the same alarm ack bit, say DB9.DBX1.1 for the same alarm in every HMI will an ack in one HMI get recognised by the others?
What is the best method of sharing the alarm ack bits so they can be acknowledged everywhere. I have seen on here a suggestion to use HMI 1 ack bit to set HMI 2 ackbit for a short time but if i have say 512 alarms this seems like a lot of coding
cheers
Have you looked at using smart access (sp?) on the Main unit, so a remote panel can take control of it?
It's a few hundred quid for the option, but might save that much in coding time.
PLC Reset
Maybe the ack must come from the PLC...
http://support.automation.siemens.com/WW/view/en/22531596
I hope this helps,
Kind regards,
Combo
Hi
cheers
I have two questions regarding the "simple object" switch in WinCC Flexible: 1. Does the switch object act as an input and output? I have...
3,719
Does anyone know if its possible to change the connection for a group of tags all at once? We have multiple similar machines all connected to...
4,855
I'm continuing my Siemens education. I need some help with compatibility details. My customer has a machine that was made by a company no longer...
4,044
Hello all. I mainly work with Siemens PLC's and panels for our machines. But now I am faced with a pilot project that has to be as price friendly...
8,991
Hi Folks. I have an older application that weighs pallets and prints labels for them. We used to capture the time/date of weighing, but we...
1,625
