Wireless control of electric winch
rguimond
Jul 2009
Escuminac
666
I'm looking for a supplier of a three-position rotary selector switch (momentary, spring-return to center) that I can use to control the operation of electric winches. I could easily control these with a wired switch, but would have to contend with a wiring harness and plugs so it could be easily disconnected when the implement onto which the winch is mounted is removed, along with the problems associated with dust, ice, corrosion, etc.
BTW, the winches will be powered by a battery mounted to each implement, along with a solar panel to maintain charge (winch is used infrequently, and never more than a second or two at once)
Current capacity of the dry contacts on the switch receiver isn't a concern, as the contacts will only handle solenoid coil current.
Switches need some sort of electronic "key" to avoid interference with units working in close proximity
I need approximately 70 units
I'm looking for a simple, cost-effective way to control traffic lights from a central location. The lights are actually mounted on signs next to...
1,870
I have Control logix plc L30 1769 plc and I want to connect temperature sensor wireless. Temperature sensor I am using is COMET Wireless IoT...
1,831
I Have one large traffic light by our RR crossing. I need to add 4 more lights in the open yard. The 4 new lights will be no more than 800 yards...
2,985
Hello, First, I have to let you know that I'm from Taiwan and English is not my native language so if you cannot understand my question...
3,450
I am fairly new to the automation industry and I was wondering what options are available to interact or control via wireless with a PC. I know...
4,795
