WonderWare, DASABCIP and String Program Tags
WildeKurt
Jun 2009
Keokuk, IA
143
I'm new to WW so be gentle....
I'm having trouble communicating with tags from the runtime environement, through DASABCIP when I try using string program tags (WW I/O message). Discrete I/O and I/O message to controller-level tags seems to be OK. In the DASABCIP console under the Diagnostics->Messages folder I see the tags that are working but don't see anything for the string program tag I'm having trouble with. Here's what I have for an item name:
Program:GMT900.KP_Sta1
Everything else is the same as with the working tags. Have I formatted this wrong?
What is your PLC? What is the tag type that you're trying to access? Tell us as much as possible -- we can't read your mind. We don't know your system. You're going to have to help us help you...
This is the key for me, when you say Controller Level, I am assuming that you are meaning Controller Scoped?
Are you sure that you have the format correctly? I have not done this in a while, but could probably do some testing later to confirm.
I dont think you can access program tags with wonderware. might want to check into that.
Interesting, I know this works with FTME (well you would hope so anyways!!).
I did have an instance a while back, when a customer was trying to do it, and I think they had it locally scoped. They were not as competent as they should of been to understand the difference, but I think they changed it to global.
I will defintely check now.
You should be able to access locally scope tags. Assuming this is a ControlLogix, your format 'Program:GMT900.KP_Sta1' is correct if GMT900 is the program name and KP_Stal is the string tag defined locally under GMT900.
Try restarting the IO server or pc to initialize the tags.
Sorry, forgot the controller: AB CompactLogix.
I was able to get the string tag to read but not sure how. I'm following the format giving in the WW docs for the DASABCIP driver. It seems starting and stopping it may be the issue or perhaps changing/adding tags with WindowMaker on (?). Anyone else have issues?
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
189
I'm using DASABCIP v5.0 with an InTouch app in 2014R2 and I am not able to make a connection to the controller. Is there a newer DA server that...
6,221
Hello, This is my first project with WonderWare Historian so i am a newbie if it comes to this. I am using the Historian to connect to a...
4,430
Hi guys, I'm working with my AB ControlLogix PLCs and my task today has been trying to get the PLC to talk to my Intouch HMI. I started out with...
3,226
Hey folks, Just yesterday I upgraded and old L1 processor and its ENBT module with a new L71 20.015 and EN2T 10.00?. The L1 was used for nothing...
4,895
