Using Yaskawa V1000 to drive a 2ft conveyor with has 1HP motor and motor rated current at 1.83A.
I am running the conveyor the whole day, after it running for a couple of hours it will start giving ol1 fault. I try to monitor the current which stays lower than 1.83 the whole time and even at the time of the trip I saw the current was 1.51amps. I do not understand why it is giving me the overload fault.
I am running at 7.5Hz speed the whole time, at a very slow speed(is the application requirement)
And this conveyor is between two heating units, initially, I thought the motor is overheating because of the surroundings but even if that was the case I should have seen the current spike drawn by the motor, which I do not see.
And the motor does get heated up pretty bad too(but the current draw is normal).
There is a gearbox 30:1 to reduce torques/load.
Has anyone of you experienced the same thing and solution?
Thank you,
Thank you,
