RSSQL, RSLinx, ControlLogix5xxx series PLC
I plan to have a setup where RSSql reads datapoints from a PLC via RSLinx and attempts to insert them into the database. If the database successfully inserts the row then I'd like to continue operation; however, if RSSql fails to insert the row (postgresql issues a REJECT on the tuple) I'd like to issue a command to the PLC to stop operation. Do I need RSView in order to issue this command or can RSSql combined with RSLinx issue a command to the PLC to stop operation. Can RSSql even recognize that the insert failed? How does RSSQL issue that command to the PLC?
Thank you,
David Ziman
Hi, I am currently in need of help with regarding of the ways on how to connect RSSQL to suitelink without using 3rd party driver...your reply is...
1,269
Hello all I am a student and also very new to PLC's and RSSQL. I have a situation where I am trying to link rslinx classic to ms sql through rssql...
2,707
I'm trying to get a string from the plc and store it in a database, but I can only get the first byte, I know there should be an easy solution to...
2,118
Hi Everybody, While I am trying to start configure RSSql,I m getting Error(33190)'The service could not validated using specified username and...
3,815
Hey all, I am trying to define data points in RSSql and am having some problems. I have a ControlLogix 5555 controller and an OPC topic set-up...
4,161
Top
