FTView Translation Utility
MATT116
Dec 2009
Dallas, TX
330
Anybody ever use this? I cannot get it to work...I just sits on the processing screen then eventually goes to "translation failed for more information please check the error logs"
There's nothing in the error log folder...
I followed this step by step
Knowledge base ID 481190 https://rockwellautomation.custhelp.com/app/answers/detail/a_id/481190
system specs:
Win7 Pro SP1
excel 2010
FTView Translation Utility v1.3.3.0
I haven't used it much, but I've used in the past without problems. My interfaces were simple enough even I could do the translations. :)
I just stepped through that KB article and it worked as described. I have the same versions as you do Win 7 Pro SP1, Excel 2010, and translator 1330.
Does the exported excel spreadsheet look okay? I got 73 rows of components ready to be translated.
I believe that my file is just to big for the translator. The export file has 2067 lines will have to look at breaking into smaller files then combining back into one.
Thanks for the reply
Oh you're trying your own file first. I thought you said you were doing it exactly like the document said.(n)
Just a thought are you offline or possibly have a firewire that is preventing the program from going to Microsoft Translate? That will cause the error to pop up instantly.
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
165
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
207
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
87
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
86
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
245
