View Single Post
Old June 16th, 2021, 03:21 PM   #9
ThreatLevelMidnight
United States
ThreatLevelMidnight is offline
Quote:
Originally Posted by roxusa View Post
I should note that if you are setting your servo up for absolute positioning you will need to provide the home sensor and also set up the servo for how it is to implement the homing cycle. With absolute positioning you are always moving to a position referenced from home, such as a drill. When I am using the servo for an application like a belt feed. There is no need for absolute and I only give direction and how far to move
I am planning to do Incremental positioning. The cycle will be a drill "peck" cycle (down, retract some, down more, retract etc).
