Logix Studio v31 Fatal Errors
Derp-Dee-Drrr
Jan 2015
Phoenix, AZ
Hi, I recently started using Logix Studio v31 after having been using v20 for years. I keep getting these fatal error seemingly at random a few times a day. It always seems to happen when I am editing code, logic, desc, etc. Each fatal error has the same error code in the log, as followed:
Any help would be greatly appreciated.
Fatal Error!
Application Path: C:\Program Files\Rockwell Software\Studio 5000\Logix Designer\ENU\v31\Bin\LogixDesigner.exe
Elapsed execution time: 23 hours, 56 minutes, & 9 seconds
Version: V31.01.00 (Release)
OS Version: Windows 8 32-bit
Thread Id: 000007f4 (2036)
Error 0xe06d7363 (-529697949)
RxEXCEPTION_MICROSOFT_C_PLUS_PLUS - A Microsoft C++ exception was generated but not handled.
I would start with try to "Repair" your installation of Studio 5000 v31.
Go to Windows Control Panel>select your software installation>then select "Change" which will start the InstallShield Wizard that will allow your to "Repair Installation".
Hi, I know I had to do a repair on Factory Talk Services manager for something very similar. Also, there may have been a recent update on your PC that is causing this. I had to get A-B tech support to check into errors one time and they went in and deleted an update to Windows, and it cured it. However I believe it was Windows 7. Hope this helps you.
Long story short we recently purchased studio 5000 and I foolishly installed v31 thinking it was the latest and greatest and found I couldn’t work with the stuff we had programmed with v29 I uninstalled(not knowing I didn’t have to) v31 installed v29 and started getting the very same errors. We don’t have tech connect but I did call the installation support number and found that it was due to corrupted registry files dealing with visual c++ they were very helpful I tried removing the windows update and all I got was a nasty conversation with it threatening to remove my administrative rights on the computer it boiled down to different versions came with different versions of c++ and they didn’t talk and play well together
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
129
Hey Guys, I am looking for a cr@cked version of Studio 5000 Logix Emulator V28 or Rslogix5000 V21, which will work with my current emulator...
267
Good Evening , I have version 28 of Studio 5000 from a few years ago . If I got a new CompactLogix CPU , what is the lowest version of...
467
I have installed Studio 5000 Professional version V36 a time ago and installed today Logix Emulate V36. I have a exsisting PLC program, but...
691
Hi all, I'm going to start programming a 1756-L73 and I'm still waiting for the full Studio5000 to be able to start at it in earnest. But I...
423
