View Single Post
Old June 17th, 2021, 03:26 PM   #15
roxusa
United States
roxusa is offline
Absolute just references once and as long as power is left on it will calculate all moves from home position. in absolute if you trigger a move of 10 revs it will move 10 revs
(direction determined by initial setup) then next move is 20 revs it will only move 10 more
revs to be at 20 revs. in incremental it would move 10 revs on the first trigger and then 20 more on the second trigger and be at 30 revs
__________________
B.Pedersen
if you are going to assume, assume you're wrong.
