Help in developing this ladder logic!
hisaurabh
Dec 2012
Mumbai
Help me building this logic in AB’s ladder logic format. I have ControlLogix PLC.
In field, I have three pumps connected in series. Say Pump-A, Pump-B, and Pump-C.
Every time “START” bit goes TRUE, two of the pumps should start but not the third one.
In below combination:
START = Start (Pump-A and Pump-B)
START = Start (Pump-B and Pump-C)
START = Start (Pump-C and Pump-A)
And then again… same cycle repeats.
Please note that I have only one “START” bit … I mean, had there been three different “START” signals I could have placed them to start in above combination. Every such START command will stay TRUE for 4 hours and then will remain FALSE for one hour. Then again START command for 4 hours…and so on. BUT EVERYTIME THIS START COMMAND COMES; PUMPS SHOULD START IN ABOVE COMBINATION ONLY.
This logic is because I do not want same pair of pumps to run all the time and get heated.
Please help in developing this ladder logic.
Thanks in advance,
Saurabh
What you are looking for is "Pump Sequencer Logic"
Googling the above search term will give you some good info.
Here is another thread with the same and a sample program:
http://www.plctalk.net/qanda/showthread.php?t=41143
You should also have switchover to a good pump if a running pump fails.
Thanks! I did do a search for that.. there are many such interesting logics available! A lot to learn from...
please help me . I have to make this ladder diagram and I can’t figure it out :(
131
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
155
Hello, I am trying to replicate a piece of logic on the PLC5 onto an SEL RTAC. I am using ladder on SEL and FBD. I am having issue on the ladder...
152
335
