OT- Equipment feed
Jim G.
Nov 2007
Georgia
187
We have a new line being added in one of our facilities. In our switch gear, we have a spare 400A breaker which we were going to use to feed power to the line. The OEM spec's state they only need a 125A feed. Which would be the better approach? Replace the 400A breaker with a 125A or feed a sub-panel with 400A service and install a 125A breaker in that panel?
Is this a matter of opinion or are there some NEC guidelines to consider?
Personally and from experience I would go the sub panel route. I have ran 400 and 200 amp sub panels for all our new lines. Not knowing what all your lines consist of but mine they are always wanting to add some other little piece to the puzzle and I have a sub panel to add more.
+1
After a new line is installed and improvements start coming, having the extra power will come in handy.
Thanks for the input.
Will go with a sub-panel installation for the convenience of "while you're at it, can you add this?"
I agree with roxusa, it'll cost more upfront but it'll save money down the line when (not if) things need to be added.
Hi, I am working on automating an industrial fabric shrinkage tester to replace its outdated electronics with a PLC. To get the tank's water level...
502
I have a lot of different equipment that I inherited from my father's company, he allowed me to sell it, how can I do this? Siemens Simatic S7...
259
Hello all I have the opportunity to buy some second hand unused components, they are Siemens motor modules, a CPU, inputs and outputs. I have...
16
2,054
Hi All, I am starting to Practice Equipment Phase program building(Batching). I am unable to find Add on Instruction "PMIntfc_LBSM" which is...
565
Hi, I'm a retired PLC developer and have some IDEC PLC equipment that was used for development that I would like to sell. Everything is in...
1,114
