ezbz
I realize that this is a PLC forum, but I need help with a VFD situation. I am using two drives in master/slave orientation. A Powerflex 755 as the master and a Powerflex 753 as the slave. I need them to run in torque mode so there is a quadrature shaft encoder on one of the motors.
Here is the question, does the slave drive need the encoder signal as a torque follower? Or can I just use the signal at the master?
