islman1975
- Join Date
- Jan 2005
- Posts
- 16
I'm attempting to read some strings from a S7 300 PLC over ethernet. I'm using a IBH S7 Link mpi to ethernet converter and then use IBH OPC server to read write data from Wonderware. I use the following method of adddressing for a string DB100.DBT0[20]. I appear to get two square characters when the string is null and then two square characters infront of any string data which is in the string. Any ideas. I think i'm just going to remove the squares in scripting.
