Stuck in Module Definition for Anybus - RSLogix 5000 V20.04
harryting
May 2002
Puget Sound
2,595
Well, this is another new one. I'm sure I done this exact procedure before and didn't have issues then but now I'm no Logix 5000 V20.04.
I'm adding a AnyBus protocol gateway on the IO configuration tree. Got the EDS installed and it shows up just fine in Adding Module but when on the page that opens up when one click on the [Change] Button under Module Definition in the General tab - It won't let me tab or click anywhere else when i tried to change the size. See the pic here. The only thing I can do is press ESC and get out there.
ideas? Search didn't turn up anything.
Have you attempted to add a Generic Ethernet Module instead of going the EDS AOP route? EDS AOPs are known to be a bit "hit & miss", depending on the author. I'm sure there will be a guide for adding your gateway adapter using the Generic Ethernet Module option in RSLogix 5000/Logix Designer?
It would do you no harm to quote the exact model and catalog number of the product you are attempting to add. This may help us in finding you some more relevant information or indeed spark some other reader's memory into life.
Regards,
George
HMS told me it was a bug in logix and v25 has it fixed
I personally edited the EDS file and reimported it to suit my io size
I have a relay output card that keeps having issues but with different relays. Every couple of weeks or so, an output relay will energize but will...
2,194
Hello all, I´m working with a Kinetix 5500 servo drive connected to a CompactLogix PLC... Last week the machine was powered off and disconnected...
2,051
Stepper Module 1746-hstp1 I have read the module on this thing a couple times now. I am still not quite confident that I am understanding...
1,172
Dear all, good evening. i am facing one problem regarding PLC .inwhich my process is going on & one of the module gets stuck up with the some...
2,015
Hi, I am using M221 reading from 3 different sensors (modbus rs485) sharing same bus (daisy chain). I am currently using READ_VAR (in total...
84
