Factory Talk View SE - Multistate indicator Animation
smess.cle
Feb 2020
Marseille
Hi everyone,
I have an object which is a multistate indicator and I would like it to move horizontally and vertically with the Animation feature. It is unfortunately grayed out for the multistate indicator.
I know there is a way to do it because I saw some runtime with it.
Any idea how to do it?
That object only allows for visibility animation. As a workaround, you could create your own version of a multistate indicator. Just need a rectangle with color animation and a string display with an expression defining the text you want displayed. That would allow for the full range of animations.
There are several other objects that are limited to just visibility animation. I think the idea behind this restriction was that an operator using the system shouldn't have to hunt on-screen for status information. Just a guess.
OG
Hi Operaghost,
I believe there is another way: grouping objects which are having the ability to be vertical/horizontal animated with that particular multistate? isn't it?
It's just I can't recall the exact way...
I grouped a simple rectangle that had all animation options (except OLE Verb) with the multi-state indicator. This new group still only had animation visibility.
OG
I wonder if duplicates of the object could be created in different locations, and only make visible the one in the desired location.
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
320
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
287
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
589
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
363
Is there a way to choose the base font in ME. Text in the Arial Unicode MS which is the default font on my FTVS doesnt show up properly on a...
678
