S7-1200 and Chlorine and PH levels
DLMUK
Jun 2013
Southampton
311
I am designing a system for a swimming pool, I am looking for a chlorine sensor and pH level sensor.
Can anybody suggest sensors which can be connected to a S7-1200?
Is this a commercial size pool?
There are products specific for the pool industry. Most will have 4-20mA outputs. The biggest difference is cost and reliability... some chlorine sensors require a lot of calibration and maintenance.
I haven't done much in the pool segment but in water treatment, Prominent make some good products. I believe they also have gear specifically designed for swimming pools.
Otherwise, Evoqua (used to be Wallace & Tiernan) are very good but also expensive.
Or the Crius from Process Instruments. More cost effective, we had some issues the transmitters not being very robust, but i feel that was partly due to employing fat fisted Operators...
https://www.processinstruments.co.uk/instrument-controllers/crius/
Endress & Hauser are some of the most reliable I have ever come across, used them on many systems, compared to ABB & others I have come across they out perform & reliability is second to none. In one plant we had over 200 instruments from conductivity to level & pressure a number of them were of other makes, due to a number of failures we replaced them with E&H, as far as I can remember we only had 3 failures over a 20 year period of the E&H, two of those were due to corrosion of the terminals (very hot, wet & corrosive environment) the other was a board failure.
Just a thought.... have you thought about changing over to a salt system?, I did and will never go back, its a lot cheaper, its so much better for your skin and easy to maintain
Not a bad question...
It uses the salt through an a cell and generates the chlorine
Some reading material https://www.hayward-pool.com/shop/en/pools/salt-water-chlorination
The main things is keep the PPM around 4000, I use about 15 bags of salt when I open the pool in the spring and a few during the summer, I tied the control panel power to my timer so it would only run when the filters were running, its a low level of salt and a low level of chlorine so easy on the skin and eyes
Edit I also found the water clarity was better... nothing like diving into a pool that was perfect
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
249
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
79
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
118
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
127
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
178
