Powerflex 753 Same Phase Output and IPM Overcurrent
TempUser1
Jul 2021
California
Hi everyone,
I have a AB Powerflex 753 powering a simple 480V permanent magnet motor using flux vector control (I believe it's the only control mode with PM on Powerflex 753). When I tried to autotune the motor, I got Event No. 35: IPM Overcurrent. When I skip autotune and just enter the motor data manually, I get the same fault. I've checked the motor wiring, reset the VFD to default parameters, neither of which have solved the problem.
I've checked the drive input with an O-scope, and I'm getting proper readings (correct voltage, all 3 phases), however when I check the output, all three lines are in phase. I'm certainly not a motor expert, but this seems to be a significant problem to me. Has anyone seen this before?
Thanks.
From the manual: The current magnitude has exceeded the trip level set by P1640 [IPM Max Cur]. Set this value to 0 only when the drive is set to the V/Hz or
SVC mod
How to remove faceplate from power flex 753 and not shutting the system down. What parameters should i change?
105
Hi all, I am having a problem with a powerflex 753 we have on site and keep getting input phase loss. The drive has been running for a long...
1,351
Hello Friends, We have a powerflex that stopped working sometime last week. It doesn't communicate over the network, or use CCW directly from my...
452
Hello all! I am fairly new to the world of PLC's and this forum, so I apologize for my lack of knowledge. I have a Powerflex 753 that keeps...
559
I am bench testing a PF753 (20f11nd096aa0nnnnn). I replaced the IGBT's and IC's in the firing circuit. Upon power up, I get the STS light...
716
