PV Cable
Tim Ganz
Dec 2010
Dallas, Texas
689
I have a panelview 2711-B5A1 that we need to connect to a slick 5/02 application and I can't seem to determine what cable I need to make or buy and I am looking for some direction?
You've got a heck of a spectrum of stuff to work on this week, Tim !
Double and triple check that PanelView terminal's part number and network plugs.
2711-B5A1
The "B" means it has Both touch and keypad.
The "5" means a 5.5 inch diagonal screen
The "A" means monochrome; it used to mean "Amber" but that was in the early 90's.
But the "1" means it has a comms daughtercard for Allen-Bradley Universal Remote I/O (RIO).
To connect to an SLC-5/02, that controller would have to be equipped with a 1747-SN RIO Scanner module.
It would be far more common to use a 2711-B5A2, -B5A3, or -B5A5, which have a native DH-485 protocol network port, same as the SLC-5/02 has.
2711-B5A1
2711-B5A1 is the right number. I guess i have to connect to this with one of the old PIC boxes?
Also i have some 1747-SN modules for blue hose can that be configured to talk to the panelview over bluehose?
The 2711-B5A1 has only a Universal Remote I/O (blue hose) adapter network interface. The RS-232 port is for upload/download, or you can use the PC Card slot for file transfer.
If you need to connect this PanelView to an SLC-5/02 based control system, you do need a 1747-SN Scanner module.
This is literally 1990 technology and products, so there are certainly folks who know how they work and can help guide you, but don't be surprised when you have to do some digging to understand the protocol and addressing.
Are you repairing an existing system, or automating something with the dregs of the obsolete parts bin ?
The old "PIC box" is the 1747-PIC for interface to Data Highway 485 (DH485) networks. You'll need a DH485 network interface to connect to the SLC-5/02, but it won't do anything for that model of PanelView.
The general purpose serial port driver for the 1747-PIC doesn't work with any modern Windows OS, so most people get the 1747-UIC modern USB version, or an equivalent from plccables.com
I have an existing machine that we are adding some functionality. Currently every cable such as a cable going out to a 4-20 psi sensor for example...
147
Hello everybody, I believe that I will find experts here who have already solved a similar topic. I need to calculate the length of the...
324
Dear all, I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable...
100
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
51
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
150
