Use Increasemental Encoder to Calculate Flowrate Question
Nan
Jul 2015
louisville
126
Hi Everyone,
I am new to srevo control, and hope to you guys can help me.
I have a Siemens s120 controler and drive, drive a cylinder up and down to supply flow rate.
It is a simple speed control with give servo the RPM speed command, I mapped the encoder vaule back to the AB plc, the value is from 0 to big number (32 bit)
I have pusles per litter information to display the actual flowrate, right now the question is that how can I monnitor the pluses change rate acrrutly?
The genetic moudle RPI for s120 controller is 20ms, I guess I can record the pluses vaule until it changes then compare them, the different will be the pluses during the 20ms, right? If this is wrong, is there a better way to do this?
Thank you!
To get running averages of a system, you have to specify a sample time τ, get the quantity δ in the given τ, and for dynamic systems, get the value using mathematics for t=0->τ
Set δ = 0 in the beginning of measurement.
So, for t in (0,τ] rate = δ /τ,
for n=1->inf, rate(n) = δ(n)/{τ(n)-t(n-1)}
So, your sample times would basically be based on timesteps indexed by n. Delta(n) would be your current pulses, delta(n-1) would be previously recorded pulses, and t(n)-t(n-1) would be your timestep length. Make that using function blocks for bonus points.
Regards,
-PreLC
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
238
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
990
Dears, i am trying to change the series of encoder from A to B, but the program do not has this option (Rslogix5000, 20.06 the old encoder was...
208
Hi all, I am working with an incremental encoder (ABZ signals, 360 ppr (so 1440 counts per rev)) to replace the existing "manual" encoder wheel I...
51
2,598
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
164
