PowerFlex 40 Multi drive to PowerFlex 525 Multi Drive?
stretch_af
Mar 2011
Drinking in Wisconsin
69
I have a machine with a CompactLogix ver20 and PowerFlex 40 multi drive node. That PF40 has a Comm-E ethernet adapter and has four PowerFlex-4Ms daisy chained off the serial port. That PF40 needs to be replaced. We are going to replace it with a PF525. Obviously I'll have to rebuild the node in the PLC and download. Are there going to be any major hiccups setting up the Multi drive device and keeping the PowerFlex-4Ms daisy chained?
Justin
I had to replace 3 PowerFlex 40 multi-drives that each had 3 PF4M daisy chained off the DSI port. The PF40s had comm-e cards installed for...
2,422
Hi All, Tearing my hair out! I have had this working in the past but cannot figure out what is wrong now! Simple set up. PF 525 set up as...
4,110
I have a problem with 2 powerflex 40 connected via 22-comm-E (multi-drive) with a compactLogix L32 controller. I'm sure I've correctly set all...
4,488
System: 1769-L23E Processor PF40 mounted with an 20CommE qty 4 PF4s daisy chained RS485 to PF40 I keep getting an F071 which is called "Net...
4,017
I am attempting to perform a "scattered" read of parameters on a Multi-drive setup of 1 PF40 and 4 PF4 drives over EIP from an L23E. The 22-COMM...
2,124
