ethernet cables for drive-cliq connection to sinamics s120 ?
If they claim that it is "Ethernet" you should very well be able to use "Ethernet" cables... now connectors? That may be different, not everyone uses RJ-45 with their "Ethernet".
Hello,
First you have to specify if you are asking about the Gray Drive CliQ cable used for internal cabinet connections (i.e.CU to MoMo) or the Green Motion Connect Cable typically used from motor encoder to drive. To answer about the green Motion Connect cables - ABSOLUTELY NO!!!!!
The Gray Drive CLiQ cables are a crossover connection typical of what is used with standard Ethernet cables. The problem is these standard Ethernet cables found in your office are not suitable for use in industrial cabinets and will most likely lead to sporatic problems and void warranty. The Drive CLiQ cables supplied by Siemens are industrial hardened (noise immunity) and system tested to assure fault free operation. So in a pinch, Yes you could use any Ethernet crossover cable instead of the Gray Drive CLiQ cable for testing but you are asking for trouble if you do not replace it before commissioning.
Regards
Hy, can we use shielded ethernet cables for drive-cliq connection to sinamics s120 components? Will any problems happen? I contacted siemens...
4,216
Can anyone recommend a flexible 600-volt shielded ethernet patch cable? I have used them from Allen Bradley / Panduit before and they are too...
61
Is there really any difference? I see the ethernet are typically colored teal and the profinet green. They appear to have the same pinouts - and...
6,679
If you run into the ugly problem of terminating waterproof underground-grade ethernet cable, with all that gel spewing out of it, you can spray...
1,506
What do most do out there in regards to ethernet cabling? Buy pre-made cable lengths for use in panels? Buy a spool and crimp your own? If you...
29
7,460
