PXR4-TCY1-5V-Z temp cont modbus ?
deljvk
Mar 2015
angeles
21
I have a Fuji temperature controller, and I'm verifying whether it is modbus protocol enabled or not. The exact model number is "PXR4-TCY1-5V-Z".
I tried every physical connection, swapping cables, and swapping terminal points and still got no data until I double check again the exact Model number above. Any idea if its a modbus compatible?
Thanks.
Regards,
J
In catalog, there is explanation that PXR4 doesn't support communication options.
I dont want to argue about, but they even have a manual about modbus on this PXR4 model. In addition, there is even an RS485 terminal diagram on the unit itself. I am thinking if I maybe missing an option.
Regards,
j
Good day ! I hope someone is willing to give me advise.... I'm new to programming over RS485 I have a G306A000 that i want to be able to...
3,316
The objective: Reach about 10’ horizontally into a 1300F furnace, and pick up a 140lb rectangular container, then pull the container back out of...
1,861
Hi Everyone, We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC...
613
We have a small plastic parts oven (SP at 210F). It used to have an old bimetal temperature regulator. We are upgrading it using two temperature...
1,529
We have a vertical Axis which was overheating while not moving. After further investigation I found that when the axis moves upward to a...
1,202
