Hi All,
I need to download an older version of a program to a PLC5/20.
Seemed easy enough. I am getting a constant error massege. Then download will stop. I don't think the problem is a corrupt file since I have tried 3 or 4 different versions from different sources. I first tried to download the file on my laptop hard drive. Then I tried a different version from the server backup hard drive. Don't have a clue at this point as to what to do. The current program in the PLC is corrupt and won't run at all. Can anyone help? Maybe I need to clear the processor memory and satrt from scratch.????
Here is the error message:
Download Failed!
Download Write Failed!
Insert Instruction Failed: Ext Sts=0x12
Invalid Parameter in Command
section=Program,file=2, element/offset=1959,length=198
Thanks for any help.
Tony
Download Failed!
Tony
