AB L32 to L35 Serial Communication
I think they are very similiar processor, if memory serves and both have ethernet port. So why not go through ethernet?
Yes, I believe you can do serial to through DF1 by using a null-modem cable.
They are on different networks and different gateways. One is connected to a dial in modem.
Yes, either of those controllers can send tag reads or writes to the other over the serial port. You would use an ordinary "null modem" cable with pins 2 and 3 swapped, like the 1747-CP3, or an equivalent serial link.
It would certainly get better performance if you bridged the IP networks instead, but if you can't or don't want to, that's fine.
They won't give you IP -> DF1 -> DF1 -> IP general protocol bridging, just controller-to-controller MSG instructions and some RSLinx/RSLogix functions.
I have a project using the Micrologix 1400 L32BXBA. i found in the manual which outputs are the Fast outputs. I know there are a few Fast inputs...
304
Hello everyone, We have an L32 processor on 192.168.1.x subnet and our corporate is now asking us to connect all our machines to their network...
1,126
Logix5000 Task monitor will crash when I point it at anything. It loads symbols etc but then after it displays it all it crashes. Pointing it at...
2,558
OK. I know there are lot of threads already to do with VPN and remote access. But after reading slot of them.i seemed to get.more confused. So I...
2,622
I have a device that is communicating RS232 data in "Real32". Is that the same as a "Real" in Controllogix? The reason is the Generic Ethernet...
1,581
