S7_1200 open user communication with barcode reader
Hossamhegab
Sep 2019
Cairo
23
Hello all ,
I have a project including S7-1200 and sick sensor lbc642
I need to communicate with the camera through ethernet tcp/I using t_send and t_recv blocks .
I have established a connection using t_con but I don't know how to begin sending commands and receive
Results , for example how can I trigger the camera and read the result (bar code).
Attached command list of the camera.
Thanks for your reply
My question is how to read the barcode scanner result to display it on HMI.
After dropping the TRCV_C block what should I do to get the result.
Watch the video that I linked to, it shows you how to send data and how to read data. Start simple by sending the camera the signal to tell it to take a picture.
Now that baref00t25 has found that the Sick sensor can talk Profinet there are other videos to watch, try this one on how to set up Profinet communications:
https://www.youtube.com/watch?v=Q_jOqL0Zp9s
Go here to download the manual for the sensor, read and learn:
https://www.sick.com/nz/en/system-solutions/quality-control-systems/label-checker/lbc642/p/p594856
Hi everybody, is there any one who has any experience with CM CANopen extension module for the SIMATIC S7-1200...I would like to use one,but have...
1,590
Maybe I'm getting confused because of all the topics on XIO/XIC or NO/NC instructions but I'm just looking at my PLC relay outputs on my...
4,298
Good Morning Gentlemen, I am using a CAN to RS232 adaptor to look at CAN data on a bus. Using Hyperterminal, the data scrolls through so fast...
2,139
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
216
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
71
