SAK-CO TECH
Looking for any insight on this particular problem.
I have, at the customers site, a ML1100 connected via the customers network. I am logging two values (pH and flow) every half hour to the ML1100 and then via connection with RSLinx the customer can "call up" the logged data with the Data Extract Utility. With the extract utility, you poll the controller and it will bring in the data to the extract utility which you can then write the data to excel from within the utility.
When I was completed with the project, everything worked perfectly with my laptop tied into their network. We loaded everything just fine onto one of their local computers (RSLinx and Data Extract) and had everything working just fine when I was at the location. A day later I get a call that the extract utility would not work (bring up the data). I finally figured out that they were having an intermittant address collision with another device on the network. So, back to communicating with no problem once they changed the address of the offending device to something else. I only mention this in hopes that someone else will save some time with this particular issue.
Now to the problem, when the customer is using the data extract utility, the data is comes up fine but when they click on the "write data to excel file" menu item, the extract utility is "locking up". Their IT guy says it's the latest version of excel.
I have contacted Rockwell support and they could not create the problem (worked fine for them) and I could not create the problem with my test system here (works great).
It's fairly obvious that this problem is local to their machine(s). I will be going to the customers site tomorrow to try to resolve the problem so I was hoping for any "leads" or ideas.
Thanks,
Chris
Thanks,
Chris
